Surftest SV-800 surface-roughness measuring machines are built around a columnmoving mechanism that nearly eliminates load capacity limitations. Their 31.496 X 19.685 X 7.874-in. (800 500 200-mm) measuring envelopes and long-stroke probe arms accommodate crankshafts and camshafts as well as other powertrain, engine, and similar components.
The probe arms' reaches let SV-800s measure multiple cross sections and waviness. Surfpak software functions include straightness compensation that improves X-axis linear accuracy and circular compensation, which increases accuracy of the stylus' vertical movement.
Mitutoyo America Corporation
Aurora, Ill.
mitutoyo.com
Latest from New Equipment
Oct. 10, 2007
Oct. 10, 2007
Oct. 10, 2007
Oct. 10, 2007
Oct. 10, 2007
Oct. 10, 2007
