The Lincoln Electric Co.
Cleveland
lincolnelectric.com
Inverters handle power variations
XMT 350 CC/CV multiprocess inverters include Auto-Line primary-power-management technology, a 5 to 425-amp output, and 60% duty-cycle rating at 350 amp/34 V. They have low-end MIG arc for short-circuit welding thin material, especially stainless steel. The Auto-Line technology improves performance by maintaining a steady arc during primary power fluctuations, providing primary power draw of 17.8 amp, and accepting any type of primary power without physical-linking mechanisms.
Miller Electric Manufacturing Co.
Appleton, Wis.
millerwelds.com
Monitor cooling flow
Universal Flow Monitors Inc.
Hazel Park, Mich.
flowmeters.com
Power supply runs on 110 or 230 V
Orbimatic GmbH
Peterborough, U.K.
orbimatic.co.uk
Control plasmacutter current
ESAB Welding and Cutting Products
Florence, S.C.
esabna.com
Machine showcases tilting rotary table
The C 30 U Dynamic uses the manufacturer's gantry design in combination with a 630-mm-diameter tilting rotary table to simultaneously machine alloys and nontraditional workpieces measuring up to 800 mm. Its C axis operates at 65 rpm while the trunniontype-A axis moves at up to 55 rpm (+30°/115°). An optional 280-mmdiameter rotary table mounts on the A-axis tilting trunnion for small parts.
Hermle Machine Co.
Franklin, Wis.
hermlemachine.com
High-speed machining
Mitsubishi EDM/Laser
Wood Dale, Ill.
mitsubishiworld.com
Wire EDM with digital generator
Charmilles
Lincolnshire, Ill.
charmillesus.com
Flexible grinder control
OpenCNC Grinder packages consist of hardware, software and documentation capability. Programming features include 11 wheel-dressing routines, eight grinding sequences, advanced grinding-wheel-offset tools, and an on-line help system. Each part program may contain as many as 20 grinding sequences. For control retrofitting, the package comes with wiring diagrams, documentation, and prewritten PLC logic.
MDSI
Ann Arbor, Mich.
mdsi2.com
Tool grinder puts on a show
GrindSmart 620XS 6-axis tool grinders easily grind complex cutters such as ballnose end mills with 0.0003-in. radius-contour accuracy. The machine accommodates diameters from 0.008 to 0.625 in.
Rollomatic Inc.
Mundelein, Ill.
rollomaticusa.com
New handwheels
Carr Lane Mfg. Co.
St. Louis
carrlane.com
Real-time process monitoring
ATAM Systems Inc.
New Albany, Ohio
atam.com
Quick-working control
GE Fanuc Automation Americas Inc.
Charlottesville, Va.
gefanuc.com
Laser marker
Proscript Zenith 20F 20-W, fiberpulsedlasers provide marking on metal coated materials, and plastics. They feature plug-and-play, 110-V, air-cooled operation controlled by the company's Merlin II LS visualdesign software. Zenith 20Fs are also backed by two-year warranties.
Telesis
Circleville, Ohio
telesis.com
Inspect tiny openings
Gradient Lens Corp.
Rochester
gradientlens.com
Software for small shops
Lilly Software Associates Inc.
Hampton, N.H.
visualjobshop.com
New features for multispindle
The Acme-Gridley 15/8 in. HPN-8 multispindle automatic has three new features — a high precision carrier with an O.D.-carrier bearing that holds 0.0003 to 0.0004 in. on squareness of I.D. to face; a servo pick-up and backfinishing slide with back-finish threading; and a variable-speed main motor for spindle rpm with servomotor feed drive.
DeVlieg Bullard II Inc.
Twinsburg, Ohio
nationalacme.com
Profile system has inch dimensions
With inch-dimension capability, the iSeries of the IPS modular aluminum profile system includes 21 profiles, plus a range of fasteners and accessories. There are plenty of smooth-face extrusions. The IPS system is useful in constructing enclosures, machine building, industrial automation, material handling, and as machine safety guards.
Parker Hannifin Corp.
Cleveland
parker.com
Vertical bandsaws
A Tannewitz vertical bandsaw cuts tough alloys such as stainless, tool, and mild steel; brass; sheetmetal; aluminum; and plastics. There are seven models with 16, 20, 28, or 40-in. throat capacities and two speed ranges. Hydraulic tables are available for the 20, 48, and 40-in. saws.
Tannewitz Inc.
Jenison, Mich.
tannewitz.com
Machines extend coolant life
Vanson HaloSource
Redmond, Wash.
coolantxtender.com
