Koma Rotary Table And Compact Indexer
KOMA Precision will feature the compact Tsudakoma RN-100 rotary table that provides 5-axis capabilities and clamping for drilling and tapping machines and small VMCs. Also on display will be the Jauch + Schmider EIS-100 Indexer with logipos ...
KOMA Precision will feature the compact Tsudakoma RN-100 rotary table that provides 5-axis capabilities and clamping for drilling and tapping machines and small VMCs. Also on display will be the Jauch + Schmider EIS-100 Indexer with logipos CNC controller and a pre-drilled 100 mm diameter faceplate for wire and die making machines. Indexing accuracy of the EIS-100 is +25 arc sec. with repeatability of +5 arc sec.
