In addition to turning and grinding bores, diameters and end faces, Stratos turning/grinding centers from United Grinding Technologies Inc. do gear-cutting. Reportedly, the dual grinding and turning capabilities of these machines reduce processing time 25 percent compared with conventional grinding and hardturning. X-axis travels are 1,050 to 1,750 mm, with Z-axis travels of 250 mm. Stratos internal grinding systems have arbors with 150-mm aluminum oxide or CBN wheels, and 36,000-rpm spindle drives are standard. External grinding systems feature interchangeable spindle and motor units and 3,000-rpm spindle drives. Turning systems feature manually activated block-type lathe tools rigidly mounted to machine-bed pedestals.grinding.com
Latest from New Equipment
New Equipment
Surfware Inc.
Oct. 10, 2007
New Equipment
Toellner Systems, Inc.
Oct. 10, 2007
New Equipment
Superior Honing Equipment Company
Oct. 10, 2007
New Equipment
Kubotek USA
Oct. 10, 2007
New Equipment
Professional Tool Manufacturing LLC
Oct. 10, 2007
New Equipment
WEMA Vogtland GmbH
Oct. 10, 2007
