Clean cylinder heads
June 30, 2005
Sugino Corp.'s 1,015-psi U-Jet III water-washing system cleans up to six sides of complex components such as machined aluminum cylinder heads, cylinder blocks, and hydraulic manifolds.
Sugino Corp.'s 1,015-psi U-Jet III water-washing system cleans up to six sides of complex components such as machined aluminum cylinder heads, cylinder blocks, and hydraulic manifolds. Its triplex pump delivers 13 gallons/min at sonic velocities of 1,100 fps, and the company's horn-nozzle creates controlled cavitation in the washing solution. It removes chips and contaminates down to an 0.01-mg level. The machine's work area accommodates parts measuring 20 108 in. and weighing up to 22 lb. Depending on size and part complexity, the U-Jet III runs 30 to 100 cycles/hr to clean approximately 250,000 to 500,000 parts/yr.suginocorp.com
