MAG Industrial Automation Systems Hessapp Division (www.hessapp.com) is introducing the DVH250I twin spindle vertical pick-up turning center designed for high-volume production applications. The center has a work envelope of 11.8 inches by 7.9 inches (300 mm x 200 mm) and requires 64.5 square feet of floor space. Designed to machine parts up to 9.8 inches (250 mm) in diameter, the DVH250I has a shuttle-type part feeder. Axis traverse rates are 1,772 ipm (45 m/min) in the X direction and 1,181 ipm (30 m/min) in the Z direction. The twin spindle design allows parallel production of two identical parts simultaneously, or parallel production of two different parts. The center can also be used to sequentially process a single part by moving it from spindle to spindle. Each of the two machining areas can be equipped with a 12-position tool turret for static tools and powered tools are also available.
Latest from New Equipment
New Equipment
Surfware Inc.
Oct. 10, 2007
New Equipment
Toellner Systems, Inc.
Oct. 10, 2007
New Equipment
Superior Honing Equipment Company
Oct. 10, 2007
New Equipment
Kubotek USA
Oct. 10, 2007
New Equipment
Professional Tool Manufacturing LLC
Oct. 10, 2007
New Equipment
WEMA Vogtland GmbH
Oct. 10, 2007
