Mazak is expanding its Nexus product line into high-torque multi-tasking featuring a large-bore spindle. The company’s Nexus QTN 450Mmachine has a maximum swing of 33.3 in. and a maximum machine diameter of 22.8 in., a 40 hp turning spindle with 1,327 ft-lbs of torque, and a 12-station turret with a 10 hp, 4,000 rpm milling spindle. A 2,000 rpm milling spindle is available as an option.. Maximum speed on the integrated spindle/motor unit is 2000 rpm and the spindle bore is 6.5 in. Feeds are 1,181 ipm in x- and z-axes.
According to Mazak, the QTN 450M machine design emphasizes solid rigidity and construction that delivers heavy-duty machining capability while handling high turning and milling forces efficiently.The NC servo-driven tailstock features single-body construction to supports shaft workpieces and provide thrust force to 2,923 lbs. The company says the machine’s carriage and bed feature a new design that emphasizes thermal stability, and the head stock features chiller cooling for improved dimensional accuracy.
www.mazakusa.com
Latest from New Equipment
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
