Abrasive blaster provides consistent surface prep
Nov. 10, 2005
Guyson Corp. of U.S.A. says its new Model RSSA-8 rotary blast system permits more consistent surface preparation than manual blasting systems.
Guyson Corp. of U.S.A. says its new Model RSSA-8 rotary blast system permits more consistent surface preparation than manual blasting systems. The cabinets can be equipped with a turntable up to 42 inches in diameter or a custom-designed component-holding fixture. Rotation speed adjusts and turntable speed can be programmed for specific feedrates or surface speeds. These systems use as many as eight suction-blast guns or four pressureblast nozzles. Gantry-type nozzle manipulators or robots are available for complex nozzle motion. www.guyson.com
