Mitsubishi Heavy Industries America Inc.
Addison, Ill.
mhi-mmt.com
Waterjet equipment
Streamline SL-IV Plus waterjet intensifiers feature a long-lasting Hyperlife plunger seal and ceramic plunger, both of which boost uptime. A hard-seal end cap improves maintainability. The SL-IV Plus provides 60,000-psi continuousoperating pressure which, reports the manufacturer, increases cutting speed up to 20% over conventional systems without sacrificing edge quality.
KMT Waterjet Systems
Baxter Springs, Kans.
kmtwaterjet.com
Program part contours with DRO
Heidenhain Corp.
Schaumburg, Ill.
heidenhain.com
Radio probe beats interferences
Renishaw Inc.
Hoffman Estates, Ill.
renishaw.com
Toolpath for tight corners
Engineering Geometry Systems
Salt Lake City
featurecam.com
Universal machining
The milling head of the DMC 60 T 5-axis machining center ensures its universal nature in two ways — a 37.5-hp, 12,000-rpm spindle and a B axis with interpolation and 30°-swivel range in each direction beyond the horizontal or vertical for negative angle machining. The B axis is pretensioned by a spur gear for distortion-free power transfer.
DMG America Inc.
Schaumburg, Ill.
dmgamerica.com
HMC features twin pallets
Fadal Machining Centers
Chatsworth, Calif.
fadal.com
VMC drive connects to spindle
Haas Automation Inc.
Oxnard, Calif.
HaasCNC.com
Multitasking machine tackles aluminum
Mazak Corp.
Florence, Ky.
mazakusa.com
Machine design dampens vibration
The NV4000 VMC's net driving force acts through the center of the axis. The machine features five ballscrews — two on the Y axis, two on the Z, and one on the X — that reduce vibration without sacrificing speed for accuracy. A more-stable platform improves rigidity on all axes and lets machining forces travel across the machine's arch-shaped column and through its bed, forming a closed loop.
Mori Seiki
Dallas
moriseiki.com
EDMs sport new NC
Charmilles
Lincolnshire, Ill.
charmillesus.com
Grinder performs I.D. and O.D. work
United Grinding
Miamisburg, Ohio
grinding.com
CMM measures without the extras
The 7-axis contact/noncontact Laser ScanArm measurement device collects measurement data without third-party attachments, external electronics, or cables. It uses a hard probe to collect simple point variations and a laser scanner for larger data volumes. An auto-material feature samples workpiece surfaces and adjusts the scanner's settings for optimal use. The device also has infinite rotation.
Faro Technologies Inc.
Lake Mary, Fla.
faro.com
Detect part errors before machining
Vericut CNC machine simulationandoptimization software's latest version includes an Auto-Differencing function that compares cut stock with the design model to locate errors and differences. It also features tools for creating custom reports and a cuttinggraph display to analyze cutting conditions. An X-Caliper measurement utility digitally verifies cut part dimensional accuracy before the NC program loads onto the machine.
CGTech
Irvine, Calif.
cgtech.com
Five-axis machining software additions
PowerMill 5 software sports secondary-axis limiting so the generated program does not move outside any limits in the machine tool's movement range. Contact-point analysis ensures the cutting surface touches only the component. The contact-point feedrate control makes sure feedrates are based on cutting speed instead of the tool tip's rotation rate.
Delcam
Windsor, Ont.
delcam.com
Software compatible with multitasking machines
Esprit SolidTurnMill software offers factory-certified posts and accurate G-code generation for Mori Seiki, Mazak, and Nakamura machines. SolidMillTurn also tackles specific programming needs of multifunction and Swiss-style lathes and mill-turn machines.
DP Technology
Camarillo, Calif.
dptechnology.com
Automating repetitive programming
The automatic toolpathing add-on for Mastercam Version 9.1 software computerizes repetitive programming tasks by linking cutting strategies to specific layers containing geometry. The feature automatically scans each layer and programs them with the selected toolpath types. The add-on supports native Mastercam MC9 files and AutoCAD DXF or DWG files and is available for contour, drill, and pocket 2D toolpaths.
CNC Software Inc.
Tolland, Conn.
mastercam.com
Manage and monitor machine tools
GE Fanuc's i CellOEE Windowsbased supervisory software manages and monitors multiple CNC machine tools and supports operations such as parts machining, data collection, remote diagnostics, and state-change monitoring. In the event of a failure, the software quickly facilitates operation recovery. Built on GE Fanuc's Cimplicity HMI software, i CellOEE provides OEE data directly from the CNC and is capable of multiple communication interfaces.
GE Fanuc Automation Americas Inc.
Charlottesville, Va.
gefanuc.com
Machining choices
Surfware Inc.
Westlake Village, Calif.
surfware.com
Turning and grooving tools
Valenite Inc.
Madison Heights, Mich.
valenite.com
Tooling for small-part machining
Sandvik Coromant
Fair Lawn, N.J.
coromant.sandvik.com/us
Tool grade turns difficult materials
The TP3000 turning insert grade handles steel and stainless steel applications. It allows for sharp cutting edges to decrease build-up, especially in difficult materials such as soft ductile or stainless steel. Negative and positive inserts and other chipbreaker geometries are available in the TP3000 grade.
Seco-Carboloy
Warren, Mich.
carboloy.com
Transform RD/ER collet chucks
Centaur Precision Tools
Miami
centaurtools.com
Secure thin-walled parts
Carr Lane Roemheld
St. Louis
clrh.com
Adjustable collets
Hardinge Inc.
Elmira, N.Y.
hardingetooling.com
