Drill deep holes
Feb. 1, 2004
Beaumont Fast Hole Series 6-axis EDMs drill holes as small as 0.018 in. in diameter in high-strength-alloy parts for aerospace engines and other equipment. Available with 40 and 60-in. X-axis travels, the FH40 and FH60 are VMC-style machines with Siemens
Beaumont Fast Hole Series 6-axis EDMs drill holes as small as 0.018 in. in diameter in high-strength-alloy parts for aerospace engines and other equipment. Available with 40 and 60-in. X-axis travels, the FH40 and FH60 are VMC-style machines with Siemens encoder-equipped motors and drives for simultaneous 5-axis positioning of parts. A 3,000-rpm spindle, 65-amp power supply, and toolchange counter for simple electrode changes are standard. Swiveling heads permit up to 120° travel on the A axis and 360° in B. Both EDMs handle 24-in.-long electrodes.
Methods EDM
Sudbury, Mass.
methodsmachine.com
