Pump high pressures at low speeds
Feb. 1, 2005
MS5 X4 4- SEL-CDM-ADP multistage centrifugal pumps generate high pressures at low speeds, extending pump use. The pumps' flow rates are up to 500 gallon/hr and capable of heads up to 700 ft at 1,750 rpm. They feature onepiece shafts, depths up to 20 ft, a
MS5 X4 4- SEL-CDM-ADP multistage centrifugal pumps generate high pressures at low speeds, extending pump use. The pumps' flow rates are up to 500 gallon/hr and capable of heads up to 700 ft at 1,750 rpm. They feature onepiece shafts, depths up to 20 ft, and no seals. For increased pressure, extra stages are available.
Gusher Pumps
Williamstown, Ky.
gusher.com
