Davenport machine says its new Quick Change Tool Spindle Front Box will cut hours off of every setup that requires a tool spindle change. The Quick Change Box has a steel outer housing that is aligned and installed once. The quick change box has interchangeable bronze liners that are designed to be swapped in and out in less than a minute. The company says changes from a stationary spindle to a revolving spindle or to a broaching spindle can be done without disturbing spindle alignment.
Davenport says all of the worn boxes in a machine can be replaced quickly and easily without hours of maintenance. When used with the new 672-U1-SA and 672-U2-SA Universal Backlash Collars, operators can pull a complete spindle assembly out and replace it in minutes.
Features include: permanently installed and aligned steel outer housing; assembly complete with the two most common machine liners (01.125 in. and 01.375 in.); 01.656 in. ID liners also are available; and 100 percent interchangeability with genuine Davenport machine OEM parts.
www.davenportmachine.com
Latest from New Equipment
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
New Equipment
Oct. 10, 2007
