Abtex Corporation (www.abtex.com) has introduced a new deburring system that uses the company's own planetary deburring head. The Tri-Ten Series, named for its three 10-in. brushes per head, is capable of deburring both sides of a flat part in a single pass without flipping it.
A magnetic conveyor transports parts under the first planetary deburring head. After the top surface is deburred, a second magnetized conveyor draws up the part and transports it across another, inverted planetary head, which deburrs the bottom surface. A third conveyor passes the part into a degausser that demagnetizes it.
The base system design can also be expanded to include application-specific auxiliary equipment. For non-ferrous parts, Tri-Ten Systems can be designed using alternate part fixturing methods.
Latest from New Equipment
New Equipment
Surfware Inc.
Oct. 10, 2007
New Equipment
Toellner Systems, Inc.
Oct. 10, 2007
New Equipment
Superior Honing Equipment Company
Oct. 10, 2007
New Equipment
Kubotek USA
Oct. 10, 2007
New Equipment
Professional Tool Manufacturing LLC
Oct. 10, 2007
New Equipment
WEMA Vogtland GmbH
Oct. 10, 2007
