Steinmeyer, Inc. (www.feinmess.de) is offering two new postioning stages: the DT 200-SM "Plug and Play" Rotary Stage and the Open Compact KDT 180-DC XY Stage.
The DT 200-SM has a built-in dc stepper motor and controller, overall height of 30 mm (1.18 in.) and length of 205 mm (8.07 in.), weighs 2.8 kg (6.17
lbs.), can handle loads up to 10 kg (22.05 lbs.) and has positional accuracy of ± 0.15 degrees with repeatability of ± 0.01 degrees. Positioning speeds of up to 120 degrees/sec and accelerations of 1000 degrees/sec are possible.
The KDT 180 has an overall height of 32 mm and footprint of 199 mm by 199 mm (7.83 in. by 7.83 in.). Total travel is 60 mm (2.36 in.) in each direction with a straightness/flatness deviation of 1 micron. The table weighs 2.5 kg (5.51 lbs.), can handle loads of up to 50 Newtons, positional accuracy of 5 µm and repeatability of 1 µm, and speeds up to 10 mm/s and accelerations of 0.1m/s.
