Three new models take center stage in Mazak Corp.’s (www.mazakusa.com) Hyper Quadrex series of multi-tasking machines featuring two horizontally opposed spindles for turning and C-axis control, plus upper and lower full-function tool turrets. Both turrets traverse in the Y axis for off-center machining.
As the first member of the Hyper Quadrex family, the 150 MSY sports a 12-in swing, 11.4-in. maximum machining diameter and 24.4-in. machining length. Its main spindle is 20 hp and 5,000 rpm with a 2.55-in.- diameter bar capacity.
Latest from IMTS 2006
Beyond The Cutting Zone
Technology Advances at IMTS
Oct. 19, 2006
Technology Trends
Wire And Water Make For Speed
Oct. 19, 2006
New Equipment
Horizontal Machining Centers
Aug. 17, 2006
Technology Trends
Machine Simulation Module Unveiled
Aug. 17, 2006
Casebooks
CNC Complements Machine's Abilities
Aug. 17, 2006
Cutting Tool Digest
Inserts For High-Speed Cutting
Aug. 17, 2006
