Self-Serve Metrology for Lean, Mean Quality Control
By Belinda Jones
For manufacturers supplying critical parts to a demanding and competitive global market, quality matters now more than ever. One of those manufacturers is ESCO Corp., a long-established power in the design, production, and distribution of products for mining, construction, power generation and aerospace applications. ESCO promotes lean manufacturing and continuous improvement at its operations worldwide through quality management systems that are third-party certified (ISO 9001). Customers who use ESCO products to dig deep into the earth, fly at 35,000 feet, provide energy to pump oil, and build bridges and freeways to keep communities moving and prospering — are the beneficiaries of these efforts.
ESCO was established in 1913 as Electric Steel Foundry Co., and used some of the earliest electric-arc melting technology (rather than open-hearth furnaces) to produce iron and steel for castings, which were produced for streetcars and logging trains. Since then, through expansions in the U.S., Canada, Mexico, Europe, and China, and strategic acquisitions like Quality Steel, ESCO continues to raise and meet customers’ expectations for innovative metal components and wearparts.
Setting goals for continuous improvement
Like any department, those responsible for product quality must make the business case for its initiatives and expenditures. At ESCO, the Dimensional/Gage Department wanted to streamline quality control for new product development based on metrology hardware and software that provides high usability, portability, and on-demand inspection. All these sound like reasonable items on a wish list, but most manufacturers fabricate a narrower range of products than ESCO does.
For mining and construction applications, ESCO manufactures ground-engaging tools, buckets, blades, end bits, couplers, wearparts, ripper systems, shanks, lip systems, dozer packages, liner packages, shrouds and structural components. The company also builds dredging cutterheads, teeth and components, as well as rigging products such as swagers, swage fitting, dies and spelter sockets.
ESCO’s recycling product line is comprised of hammers, shredder hammer assemblies, grates, rotor caps, liners and other key components. Its conveying products include long link sprockets, drums, chains, flights, drag chain sprockets, traction wheels, engineered chain, mill chain and chain attachments.
The Dimensional/Gage Department ensures product quality in two ways. One way is physical gauging, which is fixturing on the shop floor that is used by the manufacturing department to assure a product is built to specifications. The fixturing is developed, designed and built in-house and distributed to all facilities. The other way is soft gauging, which is the use of software, CMMs and CMM programming to inspect product in a process-controlled environment for the rigors of new product development.
The department uses a traditional bridge Brown & Sharpe CMM to inspect many parts automatically using pre-written programs. But, ESCO found it needed a technique for measuring very large parts that fall outside the CMM's measurement envelope. Taylor Finley, Dimensional/Gage Engineer, explains:
"We needed to add a new tool for in-place measurement of our large parts that required no up-front programming. Many engineers working on new product development need to do a quick inspection by themselves without having to go through an operator or an engineer to program a one-time inspection,” Finley details. “We wanted a system that an engineer with little or no experience could learn and operate quickly. It takes a lot of metrology experience to run a CMM and program CMM software, taking one to two years to train the operator. Our parts are becoming more and more complex. We are not dealing with simple surfaces anymore, but intricate contours which create a challenge to measure and verify our parts."
Alex Rizzuti, lead engineer for Dimensional/Gage Department, explains, "The path to our ‘self-serve’ metrology program started with a survey sent out to engineering and manufacturing teams. They came back and said your inspection systems are great, but we need to go farther. We want the ability to bring inspection equipment to the part, plus we would like to speed up the process of time-to-market. In a group discussion, we floated the idea of this self-serve system. It was an idea that would work with the right piece of equipment, and the majority of our team got on the band wagon."
Self-serve metrology
The "self-serve" solution ESCO settled upon is ROMER Inc.’s ScanShark V5 laser scanning system, comprised of a seven-axis INFINITE 2.0 portable CMM, a ScanShark laser scanning probe, PolyWorks software and a computer. The combination of articulating arm measurement with laser scanning enables maximum surface inspection of any large workpiece. The non-contact laser scanner acquires more than 458,000 points per second for detailed inspection of both geometric and surface features in a fraction of the time of probes with lesser capabilities. The 9-ft (2.8-m) ROMER INFINITE seven-axis scanning arm has a hemispherical measuring envelope of 18 ft, and operates like a human arm. Its Zero-G counterbalance offsets the weight of the carbon-fiber arm and scanner for one-handed operation from any position in the arm's reach, above and below the midline. The arm's patented infinite rotation of the principal axes enables ESCO users to inspect hard-to-reach areas on their parts. The configuration also allows for point-data acquisition with contact probes when needed, without having to swap the laser scanner for a contact probe.
"Speed-to-market is one of our biggest ‘pushes’," Rizzuti reveals. "We cannot take five or six years to design a product. Giving the engineers a tool that would allow them to spot check their products immediately appealed to the group. Every one of our engineered products has a dedicated engineer and group. All quality work funnels through the Dimensional/Gage Department, and we program all CMMs for our facilities worldwide. For continuous improvement and shortening time-to-market, work simply cannot sit around in the queue. So the self-serve model without the programming upfront is key to our effort. An engineer needing to verify a part can book the scanner when they need it, and acquire their data in a day."
Short learning curve
ESCO's Dimensional/Gage Department is comprised of seven engineers and two technicians designated with the responsibility of ensuring ESCO fit products meet dimensional specifications. This group supports the nearly 40 product design engineers and 5 plant employees coming on board to learn the new metrology system. Today, 15 engineers are master users of the product.
"The ROMER/PolyWorks solution met our classification of a self-serve system based on the fact that with a small amount of training, any engineer or manufacturing person can check out the device when they need it," Finley explains. "We spend about a full day of training stretched out over a period of 3 -4 weeks to learn how to use the system and the software's post processing tools and analysis features. We can teach an engineer with a rudimentary understanding of dimensions, tolerancing, and datum, and a general knowledge of how a part must behave … a complete novice to metrology … and have them fully trained in a month's time. The ROMER ScanShark and the PolyWorks software have been very adaptable to our in-house standards and procedures. With this model, we can get an inspection in 24 hours, taking a fraction of the time to scan our parts, without upfront programming and practically no setup time.
"The range of the scanner arm gives us the ability to capture complex angles and work around fixturing, which eliminates multiple setups. The arm's elbows and wrists make it is easy for us to setup a part and move all the way around it. The PolyWorks software enables us to post process point cloud data, stitch surfaces, align data, and do a complete inspection of a part using the basic analysis tools in the software, including color mapping to tolerances showing what is in spec or out of spec," Finley concludes.
Rizzuti says that most of the off-the-shelf features of the PolyWorks software worked well for their applications. "The best part of the software is that we can customize the desktop for our engineers. Removing tools from the menu that we are not using helps us streamline the self-serve model. We give our engineers exactly what they need for the job at hand, so there is no veering off the path."
It is clear that ESCO's in-house metrology methodologies keep a razor sharp edge on its competitiveness.
