Americanmachinist 451 82094cuttergrin00000054095
Cutter-Grinding Filtration
Sept. 8, 2008
Ebbco Inc. (www.ebbcoinc.com) will exhibit its new Ebbco Evolution Series metalworking filtration system for precision machining cutter-grinding applications of carbide, tool steel, PCD and ceramics. The system conditions coolants and oils down ...
Ebbco Inc. (www.ebbcoinc.com) will exhibit its new Ebbco Evolution Series metalworking filtration system for precision machining cutter-grinding applications of carbide, tool steel, PCD and ceramics. The system conditions coolants and oils down to 1 micron, while controlling temperature, to prevent thermal distortion. A highcapacity cartridge filter vessel uses five Ebbco High Capacity 623 filter cartridges, which are micron rated, for a total of 210 sq-ft of surface area. They are enclosed in one housing with an easy-to-use hydraulic lid-opening device.
Latest from Shop Operations
Stephan Pietzko | Dreamstime
BiancoBlue | Dreamstime
Divinesky27 | Dreamstime
