Additive Manufacturing in Expansion Mode
An R&D center and a SLM technology specialist develop a super-scale laser-fusing machine for lightweight automotive parts
What is in this article?:
  • Laser fusing with metals
  • Larger build chamber
  • Satisfying Daimler’s objectives
The X line 1000R is a selective laser-melting machine with an expanded build chamber, and now in use by Daimler to produce automotive components in aluminum alloys.
Additive manufacturing with metals is becoming increasingly important to the automaking industry, as time and cost reductions in production make the technology increasingly attractive. The primary focus is on aluminum alloys that are the foundation for lightweight automobile construction. For applications involving vehicle and engine technology, but also from other areas, Daimler AG is embracing “generative metal laser melting of metals.” In order to address future projects with that approach, the automaker assigned the Fraunhofer Institute for Laser Technology (ILT -- a commercially focused research center in Aachen, Germany) and Concept Laser, a specialist in laser fusion systems, to develop a new laser melting machine with a build chamber that’s larger than any previous model.
Fraunhofer ILT and Concept Laser will introduce a new high-performance LaserCusing® machine, the X line 1000R, for fabricating series components, at Euromold 2012 this month in Frankfurt. The first version of the machine is already in commercial operation for Daimler AG. It’s a new development based on concepts applied commercially in machines that Concept Laser has been developing for manufacturers over more than a decade.
Concept Laser’s LaserCusing process is equivalent to selective laser melting (SLM): it produces high-precision metallic components that withstand mechanical and thermal loads. It’s a patented technology that Concept Laser has been supplying to manufacturers worldwide since 2000, according to Frank Herzog, managing director. Depending on the application, the materials used are high-grade steel alloys, tool steels, aluminum or titanium alloys, nickel-based super alloys, and cobalt-chromium alloys. In the future, the process is expected to work with precious metals too, such as gold and silver.
In LaserCusing,fine metallic powders are locally fused by a fiber laser, causing the materials to solidify as an alloy. The contour of the component is produced by directing the laser beam with a mirror-deflecting unit (scanner.)  The component is built in layers (with layer thicknesses of 20-100 μm) by lowering the bottom of the installation space, applying more powder, and fusing again. The distinguishing feature of Concept Laser’s machines is stochastic navigation of the slice segments (also referred to as "islands"), which are processed in successive stages. This patented process significantly reduces stresses within the component.
Its important to note that the X line 1000R has an expanded build chamber, with “impressive” dimensions, according to Frank Herzog. It was developed for tool-less manufacturing of large functional components and technical prototypes with material properties that are identical throughout the range. The central design element of the X line 1000R is a high-power laser in the kilowatt range that makes it possible to increase productivity compared with standard laser fusing machines by up to a factor of 10.
The machine was specifically configured according to Daimler’s special requirements for automotive applications. The automaker’s aim was to replace sand casting and diecasting production -- both of which are time- and cost-intensive -- in early phases of development. In addition, in the future the LaserCusing process will offer the possibility of generating lightweight structures with a high level of rigidity that will permit weight-optimized geometries, with almost no restrictions on the design: such products cannot be manufactured in this way with the commercial manufacturing techniques now available.
Please or Register to post comments.
Subscribe to AM Newsletters
Connect With Us
American Machinist Marketplace - Buy a Link Now
