Wire comes in recyclable containers
April 1, 2005
Marathon Pac bulk welding wire ships in recyclable and environmentally friendly corrugated board coated with a thin moisture barrier. Sporting a special octagon shape, the wire is spun into the carton through a technique that eliminates cast and helix as
Marathon Pac bulk welding wire ships in recyclable and environmentally friendly corrugated board coated with a thin moisture barrier. Sporting a special octagon shape, the wire is spun into the carton through a technique that eliminates cast and helix as the wire leaves welding guns. Reportedly, this results in easy feed, reduces feed-motor wear, and provides precise placement of wire in weld joints.
Esab Welding & Cutting Products
Florence, S.C.
esabna.com
