THE compact Vertical Pallet Pool (VPP) is an economical option for expanding storage and automating production on one machining center. The basic model has six buffer stations and one loading station, while two-or three-level VPPs accommodate 11 to 15 buffer stations without consuming any more floor space. The SelectG universal grinder, designed for flexible, precise, small-lot work, has a wheelhead that rotates from 90 degrees to 60 degrees to accommodate either a straight or angle wheel. Single-machine capabilities are expanded without the added investment of a full CNC-controlled wheelhead or a second dedicated grinder.
