System removes fines from grinding fluids
The Turbo-Separator T22/RCS filtration system by Sanborn Technologies removes fine micron particles as it recycles grinding and polishing fluids. The system's centrifuge has a 40-gpm process rate and 22-lb solidsremoval-capacity rate. It includes a low-profile dirty and clean tank that receives dirty fluids via gravity. The clean tank has a multipass design, overflow protection and supply pump that returns clean fluid to machine tools. Discharged solids from the system are dry because of its bowl design and high rotation speeds for recovering valuable materials such as carbide.sanborntechnologies.com
