Americanmachinist 3245 9571rne0900png00000003355
Surface roughness tester
June 8, 2005
Surftest SV-800 surface-roughness measuring machines are built around a columnmoving mechanism that nearly eliminates load capacity limitations.
Surftest SV-800 surface-roughness measuring machines are built around a columnmoving mechanism that nearly eliminates load capacity limitations. Their 31.496 X 19.685 X 7.874-in. (800 500 200-mm) measuring envelopes and long-stroke probe arms accommodate crankshafts and camshafts as well as other powertrain, engine, and similar components.
The probe arms' reaches let SV-800s measure multiple cross sections and waviness. Surfpak software functions include straightness compensation that improves X-axis linear accuracy and circular compensation, which increases accuracy of the stylus' vertical movement.
Mitutoyo America Corporation
Aurora, Ill.
mitutoyo.com
