Remove submicron particles from fluids
April 1, 2005
Series 6000 magnetic filter rods for fluid reservoirs of lathes and threading and milling machines remove ferrous contaminants down to the sub 1-µ level. Reportedly, this results in less wear on pumps, dies, and other critical moving parts. It also i
Series 6000 magnetic filter rods for fluid reservoirs of lathes and threading and milling machines remove ferrous contaminants down to the sub 1-µ level. Reportedly, this results in less wear on pumps, dies, and other critical moving parts. It also increases the ISO cleanliness level of the circulating fluids so they produce higher quality products. The rods are manufactured from 316 stainless steel under a process that compresses and redirects ultrastrong magnetic fields.
One Eye Industries
Woodland, Calif.
oneeyeindustries.com
