Hocut 795-CU coolant is formulated for machining red metals including copper, bronze, and brass. Its ingredients prevent chemical reactions with red metals and protects such machined metals from corrosion. Hocut 795-CU remains stable unlike traditional coolants that change color as material builds up in the coolant sump. The fluid also works in machining metals such as aluminum, carbon steels, nodular and gray iron, and alloy steels.
Houghton International
Valley Forge, Pa.
houghtonintl.com
