Americanmachinist 1730 31819neweq0502j00000017234
New Rotary Nozzle For Pressure Washers
Sept. 19, 2006
Legacy Premier Parts & Accessories (www.c-techindustries.com) has introduced a new rotary nozzle for pressure washers that they say increases impact pressure more than 10 times that of conventional high-pressure spray nozzles. The new ...
The new nozzle attaches to the wand of most hot or cold water pressure washers and blasts surfaces with a spinning spray action at 4000 rpms.
It is rated for up to 4350 psi at 185 degrees F and can be used as a wide-coverage fan-spray, pencil-jet or 0-degree nozzle. The nozzle has a wear-resistant ceramic head and bearing ring.
