Mix coolants consistently
June 8, 2005
The Jetmix emulsion-mixing device uses cavitation to consistently...
The Jetmix emulsion-mixing device uses cavitation to consistently mix water and coolant concentrate for microscopic oil droplets less than 0.1 µ in diameter. The manufacturer reports this enhances the fluid's stability, increases performance, and decreases usage as compared with other mixing methods. The Jetmix mixes concentrate from drums or totes with a 7.9-gallons per minute throughput.
Blaser Swisslube Inc.
Goshen, N.Y.
blaser.com
