Americanmachinist 2918 Neweq0900png00000001880
Large-capacity orbital former
June 1, 2004
The Model P-1500 hydraulic orbital forming machine handles mild steel measuring more than 1.5 in. in diameter and equivalent areas in tubing, square, and other forming materials. Its maximum downward force is 38,500 lb (19 tons) at 1,000 psi hydraulic. To
The Model P-1500 hydraulic orbital forming machine handles mild steel measuring more than 1.5 in. in diameter and equivalent areas in tubing, square, and other forming materials. Its maximum downward force is 38,500 lb (19 tons) at 1,000 psi hydraulic. Tool stroke adjusts from 0.06 to 3 in. in 0.001-in. increments. Standard throat depth is 9.75 in., and vertical-saddle-height adjustment is 12 in.
Orbitform
Jackson, Mich.
orbitform.com
