Embedded motion control (EMC) technology stands out as one of the significant reasons for reductions in rotary transfer changeover times. Low cost, full-CNC transfer systems built on EMC architectures transform machine stations into flexible accurate plug-and-play units that shops can quickly and easily configure or reconfigure and position or reposition anywhere around the machine ring. This is possible because the self-contained EMC tool spindle units carry their own hydraulic servo valves and control devices and retain program information no matter where they are stationed.
In addition to quick changeovers, EMC-type machines boost part quality by letting shops use such capabilities as in-process gaging and precision offsetting, part tracking and error mapping to eliminate stack tolerances. These capabilities improve holding positions and tolerances by as much as 15 percent over previous machines.
EMC-type machines further enhance part quality because each station has infinite feed control capability for eliminating retraction marks on O.D.s and I.D.s. Being able to vary feedrates can also help reduce break-through and intersection burrs.
Contributor to this article: Hydromat Inc. (www.hydromat.com)
Comparing changeover time: Standard hydraulic rotary transfer system versus an EMC-type machine |
Collet changes: Standard = 6 min. per station for 12 stations = 72 min. EMC = 2 min. per station for 12 stations = 24 min. |
Station rpm changes: |
Changing flange adaptors: |
Changing and setting values: |
Tooling setup: |
Setting origins: |
Setting cut offs: |
Totals: |
