Americanmachinist 1863 86062emcomaierh00000058788
[IMTS Preview] EMCO Maier to unveil HYPERTURN 45 at IMTS 2010
July 20, 2010
A versatile, multi-task production turning/milling center designed for a wide range of applications on bar stock to 45 mm diameter, the Hyperturn 45, will be demonstrated by EMCO Maier. High-performance main and counter spindles, two tool systems, ...
A versatile, multi-task production turning/milling center designed for a wide range of applications on bar stock to 45 mm diameter, the Hyperturn 45, will be demonstrated by EMCO Maier. High-performance main and counter spindles, two tool systems, stable Y axis, water-cooled spindle motors, dynamic digital drives, a thermo-symmetrical machine construction, and compact dimensions make the HT 45 a high-capability production machine.
In addition to the two spindles, two turret tool systems with a total of up to 24 driven tools and a VDI25 rapid change system, as well as several automation options, the HT 45 includes a Y axis with a 70 mm travel in the upper slide system and a Z2 axis in the lower slide system. A 45mm (standard 32 mm) through-hole counter spindle is available for longer parts.
The machine can be applied in a wide range of sectors: from general mechanical engineering, job shops and the automotive supply industry, where production tends to involve large quantities, through to precision trades such as dental technology or the jewelry industry.
The main and counter spindles are equipped with integrated water-cooled spindle motors with high drive power of 15 kW, a maximum speed of 7,000 rpm and an even higher torque of 100 Nm. The counter spindle’s nose is also larger: With A2-5, the counter spindle can be used to remove bar stock parts with a diameter of up to 45 mm. Maximum turning diameter is 300 mm.
Visit IMTS Booth #S-8748
