Americanmachinist 934 82080travelingc00000054081
Traveling-Column Machine
Sept. 8, 2008
The SHW UniSpeed 5 travelingcolumn machining center from Bohle Machine Tools Inc. (www.bmtbohle.com) uses a powerful SHW universal spindle head that offers 5-sided machining and turning with 64,800 programmable spindle orientations, so ...
The SHW UniSpeed 5 travelingcolumn machining center from Bohle Machine Tools Inc. (www.bmtbohle.com) uses a powerful SHW universal spindle head that offers 5-sided machining and turning with 64,800 programmable spindle orientations, so shops no longer need to select a horizontal or vertical machine because the UniSpeed 5 does the work of both.
The machine’s 35-hp milling spindle runs at 6,000 rpm or 30,000 rpm if it’s a high-frequency model, and machine rapid-traverse rates are 98 fpm with 2-G acceleration.
Methods Machine Tools
Andreyi Armiagov | Dreamstime
