High-Productivity CNC
Sept. 8, 2008
Bosch Rexroth (www.boschrexroth-us.com) will show a broad range of automation products and applications for machine tool and CNC operation. One of these is the highproductivity IndraMotion MTX CNC system for grinding and forming ...
One of these is the highproductivity IndraMotion MTX CNC system for grinding and forming operations. Supporting as many as 64 axes of motion and 12 independent CNC channels, the system contains all the components – drives, controller, operator software and powerful engineering framework – optimized for machine tool automation.
The MTX advanced version also features a new high-end CPU for PC-based systems, providing manufacturing precision down to the nanometer range and the shortest CNC and PLC processing times for the most dynamic machining and shortest cycle times.
Methods Machine Tools
Andreyi Armiagov | Dreamstime
