Bandsaw Blades
Sept. 8, 2008
DoAll Sawing (www.doall.com) products will introduce two new bandsaw blades, the Supreme M81 and the MPB-2. The Supreme M81 is made from highspeed steel alloy and features a special tooth geometry for increased productivity and wear ...
The Supreme M81 is made from highspeed steel alloy and features a special tooth geometry for increased productivity and wear resistance. The MPB-2 has variable-height teeth, a wide set and coarse pitch for superior performance in cutting easy to difficult-to-cut materials.
Methods Machine Tools
Andreyi Armiagov | Dreamstime
