If you are unable to view HTML, you may copy and paste this link into your Internet browser:
http://americanmachinist.com/newsletter/VIP_October05.html
Your newsletter for tips on selecting manufacturing technology.
1.) Question of the month --- Do you expect manufacturing growth in 2006?
2.) Tips on Toolholding
3.) Hot products
4.) Manufacturing education and training - Free Training to Keep Tooling Jobs in North America
Tips on Selecting
Toolholding
To view the latest articles and products on Toolholding, visit American Machinist's Toolholding Tech Zone.
Effective toolholding is one key to achieving the speed and accuracy made possible by today's advanced machines and cutting tools. However, many manufacturers continue to use old toolholders in new machine spindles. This practice can hold back the performance benefits offered by new machines, and may result in the improper fit of toolholders that the company purchases later.
Shops that are preparing to buy new toolholders should keep four critical criteria in mind:
• Rigidity is achieved by at least 80 percent taper contact.
• Accuracy is determined by a maximum runout of 0.0002 inches total indicator runout (also known as TIR, a measure of the deviation between the surface of a rotating cylinder and a reference axis) at four times the diameter of the tool being held. Shank tolerances of ANSI standard AT-3 or better increase spindle-taper accuracy.
• Balance decreases vibration and chatter, and increases metal-removal rates, tool life and surface finishes. The quality of toolholders that use set screws or collets affects balance at high spindle speeds, and should consistently maintain a G 2.5 rating at the rated spindle speed.
• Gripping power is the holding power of the toolholder. Multipurpose, high-precision collets should have a wide clamping range with a 1-mm collapse.
There has been an increasing trend toward HSK and shrinkfit toolholders because of their inherent rigidity and accuracy. HSK holders should meet required tolerances when a spindle is running at 40,000 rpm. Shrinkfit toolholders are expensive but they achieve rigidity at nearly the same levels as an integral shank tool, and at a lower cost and with greater flexibility than possible with an integral shank tool. Shrinkfit toolholders impose 10,000 pounds of gripping force on a tool shank, exceeding the gripping capabilities of collet, milling and hydraulic chucks. Shrinkfit tooling should be purchased from a supplier licensed by the original patent holder to ensure the product is manufactured to the correct standards; look for the high holding power and the extreme rigidity that are necessary for precise machining; ensure the toolholder is factory balanced to 15,000 rpm or better, and demand a TIR of 0.0002 inches or better.Hot Products
Check it out
Seco-Carboloy EasyShrink ® 20 Modular Shrinkfit System
Available with or without stop rod height setting, in single or triple stations, air or water-cooled, and choice of rotary support. www.carboloy.com/epb . Manufacturing Education and TrainingIndustrial Hydraulics, and Election Drives and Controls
As part of its ongoing effort to increase the competitiveness of North American manufacturing, Cimatron Technologies, Inc., a provider of integrative CAD/CAM software solutions for toolmakers, is offering free training and support to unemployed tooling professionals.
Coming in November: AMERICAN MACHINIST will focus on Machine Tools.
To learn how to reach this newsletter's thousands of qualified readers, e-mail
Christian Webb or call him at 216.931.9501. To subscribe to this newsletter or manage your account, click here. To unsubscribe click here. © 2005 Penton Media Inc., 1300 E. 9th St., Cleveland, OH 44114. Read our privacy policy.
