Depressed Center Grinding Wheels
CGW-Camel Grinding Wheels (www.cgwheels.com) has expanded its Super Quickie-Cut line with the introduction of 0.125-in. (3-mm)-thick depressed center cutting, notching and pipeline wheels. The depressed center wheels for cutting and ...
The depressed center wheels for cutting and notching are designed to be used with steel and cast iron and are manufactured from aluminum oxide grain and R-grade bond for clean, steady cutting action.
The wheels are available in 4.5-in. diameter by 0.125-in. (3-mm) thickness with 0.875-in. (22-mm) or 5/8-11 arbor holes.
The Super Quickie-Cut depressed center pipeline wheels are designed to be used on ferrous metals and are made from aluminum oxide grain and T-grade bond for high stock removal. The pipeline wheels are available in 4.5-in. diameter by 0.125-in. (3-mm) thickness with 0.875-in. (22-mm) or 5/8-11 arbor holes.
