Americanmachinist 1773 80461mrseriesjp00000052889
Compact Rotary Tables
May 22, 2008
MR Series TX Series TT Series MR-series tables are designed for exceptional performance at an economical price. Accuracy within 20 seconds is guaranteed in most models. A robust air-powered triple disc-clamping system ...
MR Series
TX Series
TT Series
MR-series tables are designed for exceptional performance at an economical price. Accuracy within 20 seconds is guaranteed in most models. A robust air-powered triple disc-clamping system eliminates the need for a hydraulic unit.
T-series tables offer tilting, side and rear motor mounts. They are designed for the widest range of applications, including shaft work requiring a large through-hole. All X models feature a standard built-in air booster for maximum clamping force.
Designed for NC rotary table applications, a typical booster provides clamping force of 1,918 ft-lb with air pressure at 71 psi for the 320 size.
Compact Kitagawa TT-model tilting tables minimize interference problems. The TT dual axis configuration enables any compound angle and eliminates the need for multiple setups.
All Kitagawa tables feature a large worm gear module that provides a large area of contact between the worm and wheel gear. A superior new alloy is used, further reducing wear. In addition, a special cross-roller bearing prevents displacement under load. Accuracy is guaranteed within 15 seconds or 20 seconds in most models.
Latest from Cutting Tools
Kalinovsky | Dreamstime
Inovatools Eckerle & Ertel
