Americanmachinist 406 82712colletsfor00000054870
Collets for High-Pressure Coolant
Oct. 17, 2008
Rego-Fix (www.rego-fix.com) has expanded its line of ER collets with a range of metallic sealed collets. These collets are designed for applications that require throughthe- tool coolant pressures to 2,000 psi, and seal the tool to the ...
These collets are designed for applications that require throughthe- tool coolant pressures to 2,000 psi, and seal the tool to the collet and the collet to the toolholder.
The Swiss-quality metallic sealed collets are designed for universal use, and work with any standard or friction-bearing nut. As a result, users do not need to purchase special coolant nuts or disks for coolant sealing.
The collets are available in standard and metric sizes, in diameters from 0.125 in. to 0.75 in. and 3.0 mm to 20.0 mm.
Latest from Cutting Tools
