lndependence II series blades have a tooth configuration for multipurpose sawing, including cutting of small-to-medium solid steel and a combination of structural steels. Independence EXS blades have a tooth geometry for hard-to-machine solid metals, such as stainless steel; large, solid shapes; and exotics. The cutting edges on both series of blades are 70-Rc hardness for high wear resistance and long life.
M.K. Morse Co.
Canton, Ohio
mkmorse.com
Hard-turning grade
CBN350's high toughness reduces chipping and edge flaking in difficult-to-machine materials and allows for high feedrates and long life in low cutting speeds. The solid inserts are available as round or square shaped.
Seco-Carboloy
Warren, Mich.
carboloy.com
LPE tangential milling inserts
Two high-performance grades of LPE tangential milling inserts are available from Stellram. SP3014, a TiAlN PVD-coated insert, is for milling of ductile cast irons, stainless steel, and high-temperature alloys. SC3025 is for milling cast iron. Both grades fit industry-standard cutters.
Stellram USA
La Vergne, Tenn.
stellram.com
Versatile end mills
TuffCutXR end mills are AlTiN coated and are available in size ranges from 1/8 to 1 in. and 3 to 25 mm.
M.A. Ford Mfg. Co. Inc.
Davenport, Iowa
maford.com
Cast iron turning combo
The strong KR insert geometry produces low-cutting forces in demanding, cast iron roughing applications, while reducing vibration and power consumption.
Sandvik Coromant Co.
Fair Lawn, N.J.
sandvik.com
U.S. CUTTING TOOL INSTITUTE BILLINGS INDEX | ||||||
Index for January '03—December '03 | ||||||
January | $133,883,278 | 120.6% | July | $111,215,159 | 102.1% | |
February | $125,288,689 | 112.9% | August | $116,382,313 | 106.8% | |
March | $134,260,197 | 122.1% | September | $125,456,973 | 115.4% | |
April | $123,526,680 | 112.9% | October | $132,331,224 | 121.3% | |
May | $119,703,248 | 110.0% | November | $116,384,449 | 107.1% | |
June | $123,443,633 | 113.6% | December | $121,200,994 | 111.7% |
