Milling Inserts
Sandvik Coromant (www.sandvik.com) unveils two new generation milling insert grades, GC1030 and GC4240, that the company says allow for higher efficiency in steel milling. The GC1030 grade uses a PVD coating to improve wear resistance and ...
Sandvik Coromant (www.sandvik.com) unveils two new generation milling insert grades, GC1030 and GC4240, that the company says allow for higher efficiency in steel milling. The GC1030 grade uses a PVD coating to improve wear resistance and performs well in machining titanium and high-temperature alloys, while the GC4240 grade contains a new substrate and CVD coating for demanding steel milling operations that require high metal removal rates.
