Americanmachinist 2364 66338ctd0200png00000042634
HSK Toolholders
May 10, 2007
Swiss quality HSK toolholders from Rego-Fix Tool Corp. (www.rego-fix.com), manufactured per DIN standard 69893, are balanced by design to G2.5 at 25,000 rpm. Compatible with the company's ER and PG collets and Hi-Q balancing rings, the HSK ...
Swiss quality HSK toolholders from Rego-Fix Tool Corp. (www.rego-fix.com), manufactured per DIN standard 69893, are balanced by design to G2.5 at 25,000 rpm. Compatible with the company's ER and PG collets and Hi-Q balancing rings, the HSK toolholders are for use on the latest generation of CNC milling machines. They are coolant-through capable and available in forms A through F and a variety of sizes.
The toolholders deliver hollow taper accuracy to AT3 tolerances for good spindle-to-holder fit and accuracy. They are made from high tensile strength casehardened steel for low wear and long life.
